Kill switch on a carb motor
Old Mar 13, 2006 | 02:45 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
There are a LOT of recent fody thefts in my area and it's got me a ittle spooked, so I'd like to see if I can't wire up a kill switch. I'm thinking of either splicing into the ignition somewhere or to the wiring in the steering column. Which would be the better way to go, and where should I splice the wires?
Thanks.
Old Mar 27, 2006 | 05:07 AM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Do you have an MSD ignition or are you using the factory stuff? If you have an MSD then a kill switch is very easy to install. Not too sure on the factory stuff though. Although, I do remember seeing a few Cavaliers that had this special theft deterrant package. It consisted of a hidden magnetic relay located in the main ignition wire. The only way to start the car was with a magnetic keychain. You hold the keychain up to the dash in the area of the *hidden* relay, and the magnet closes the control side of the relay. You put the key in, turn the ignition, and away you go.
Old Mar 27, 2006 | 09:33 AM
305q_ta86's Avatar
Transmission: 5 spd
Wow, cool idea. You know, I think I remember hearing something like that too. I'll have to check it out. thanks.
(oh btw it's not an MSD. All factory ign.)
Old Mar 27, 2006 | 12:47 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you can cut the power wire to your coil and put a relay in series. then put a switch anywhere you want.
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Mar 5, 2017 06:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 02:00 PM
