Charging Woes
Old Mar 22, 2006 | 10:34 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Charging Woes
Here 's the deal:
Old alternator was throwing sparks (reaching a foot high) at engine speeds greater than 3000rpms. I replaced because of sparks, not because of charging issues; although I'm sure it was on its way out anyway. I went out to AutoZone and grabbed a Duralist Remanufactured one. One of my buddies works there and I can get a discount. I tried to get a brand new one (Duralist Gold?) but they had zero in their inventory.
When I got home, I proceeded to take the belt off, 2 bolts, and disconnect the hot (fat) wire and connector. Install took about 15min. Later on that night was the first time I took the car out on the new alternator. I drove 10mins away to my friends house. On my return back home, the engine started running rough. Then, when I was around 4min away from home, I happened to glance at my battery voltage gauge and it read 8-9V. Not even a minute later, my radar detector started going nuts and my stereo turned off. My headlights began to dim and started flickering. Trying to make it another 2miles home, I turned off all unnecessary electronics. I left only the parking lights on (It was 11PM). By this point, the engine was really stumbling on its face. Only good thing that happened was that I did make it home.
First thing I did when I got home was to check the connections and make sure all of my wires were held on tightly. I did manage to grab a few voltage drops:
Key off position
B- to Fat Hot wire bolted on ALT. <-----12V
B- to Pin "S" <-----12V
ALT. casing to B+ <----- 12V
These voltage drops lead me to believe I was one of the unlucky ones who ended up buying a faulty remanufactured alternator.
What do you guys think?
Old Mar 23, 2006 | 01:22 PM
Dirtbik3r's Avatar
Ok, new measurment, I have 12V from the black wire, pin F, to Positive side of Battery. All these voltage drops were done with the car not running, I have no joice to start it. I'm 90% sure its the alternater.
Anyone got anthing to add??
Old Mar 23, 2006 | 02:17 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
I would tend to agree with you.
Old Mar 23, 2006 | 02:48 PM
Dirtbik3r's Avatar
UPDATE: Brought it back to autozone. Alternater failed output test 2/3 times. A lesson is to be learned here. Just because a part is "new" doesn't mean it's not defective.
Old Mar 24, 2006 | 12:27 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
I have run into that problem my self, now I have them test all parts that they can test before I leave the store. Having them test the parts also saves a lot of time.
Will
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
