What wires do I use?
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
u cant tell from that, u are going to have test it and see which one has 12v on it when you hit the swich for the pump
There's a red and a blue wire coming out of the windshield motor that runs to the windshield washer pump.
The blue wire hooks to pin "B" on the connector at the pump. The red hooks to pin "A".
The two pins at the windshield motor are "D" and "E".
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I had to do it by trial and error, I hooked up the red and blue from the pump to the yellow and pink and I got it to work. The washer pump blows too hard because the fluid misses the windshield and sorta sprays onto the top of the car
It works though
It works though
Glowsock
Jan 9, 2017 04:06 PM
Weight reduction
