Vats Overide Please Help
Old Mar 27, 2006 | 09:29 AM
ls2twntur1200hp's Avatar
Car: 1988 Firebird Formula
Engine: 5.2 tpi
Transmission: th700r4- TCI
Axle/Gears: fourth gen rear 3.42
I'm retrofiting a tpi system into a car that dosent have vats. How do i install the resitors? I've alredy ran the wires to F10 which is the vats terminal but what then?
Old Mar 27, 2006 | 10:35 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Unless you are using the computer from a car that originally had VATS I wouldn't worry about it. If you are using the computer from a car that had the VATS then you will also need the VATS control module and the starter enable relay as well.
Old Mar 27, 2006 | 12:34 PM
Engine: 5.2 tpi
The ecm came from a car with vats. So i need the vats module? were is it located at or where can i get one.
Old Mar 27, 2006 | 12:40 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
just get a chip with vats disabled.
Old Mar 27, 2006 | 03:13 PM
Engine: 5.2 tpi
I already have a custom chip from tpis and i dont want to pay 75.00 plus shipping for a reprogram. The engine turns over just the injecters dont pulse. So i was thinking if i got the vats module and wired in the resitor it would work. I need one of those modules and how to wire it.
Old Mar 27, 2006 | 03:24 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What year and model car did you get the computer from?
Old Mar 28, 2006 | 09:58 AM
Engine: 5.2 tpi
91 Z28
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
