Shocking!
Old Mar 28, 2006 | 02:28 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Transmission: TH-350
Axle/Gears: Open...
Shocking!
Why do i always get the crap shocked out of me when i get out of my car? Its getting annoying, and sometimes it hurts! Is there something wrong with my car? Any and all information is greatly appreciated.
Old Mar 28, 2006 | 02:50 AM
Vader's Avatar
Static buildup. You can hang a ground strap under the car to help dissipate the charge. Or you can humidify the area around your car to help do the same thing.
Old Mar 28, 2006 | 03:03 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Axle/Gears: Open...
Why does it do it so extremely bad in my car then and not the other vehicles i drive?
Old Mar 28, 2006 | 07:13 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
What the seats are made of, what the carpet is made of,...
I'll add that a negative ion generator would help .
Old Mar 28, 2006 | 03:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
On occasion through my life I've had the same thing, and sometimes I found a short in some thing somewhere in the works. But many times, I've found nothing, and just chalked it up to static. Does everything seem to work? Have you disconnected/modded anything that might have a loose end? If not, it's just static. Mine will do it to me on occasion - especially when the humidity levels are low, like winter months. Next time I'm under mine maybe I'll hang a grounding strap underneath in the middle where it's not noticed.
Old Mar 28, 2006 | 07:32 PM
Jza's Avatar
Jza
There's a method of getting out of the vehicle that will prevent that during seasons when the static gets real bad. It's awkward at first, but you get used to it quickly.
When you get out of the car, put your left foot on the ground and your left hand on the top of the door (or the end if the window's up). Then you get all the way out of the car before you let go of the door. This way you're maintaining a ground on the car and the earth up until the moment you let go of the door (which is while you're closing it). I'll usually touch my wrist to edge of the doorskin so I can grab the handle with my hand which I close the door by (since I don't like fingerprints on the paint).
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
