keeps running after I take the key out
Old Apr 5, 2006 | 11:23 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
I converted to carb but that is not new and it has been running fine that way for 3 years. My fuel pump is hotwired through the original relay which is activated by the IGN port in the fuse box.
When I turn the key off, my radio goes off and the alternator stops charging, etc. But the fuel pump and the ignition both somehow still have power. I replaced the ignition switch on the top of the column and that didn't change anything.
Any Ideas?
Could there be something in the lock cylinder itself?
Old Apr 6, 2006 | 07:28 AM
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
She wants to live!!!!! lol...
Hmmm.. How do you get it to turn off then? lol.
Sounds to me, if it was in the lock cylinder, Nothing would turn off. So to me it sounds like either a wiring issue (Pump/Distributor was not wired to correct cuicut) or possibly a bad relay that is faulted on.
Interesting though..
Old Apr 6, 2006 | 09:10 AM
BadGirlIROC's Avatar
Car: 87 IROC-Z
Engine: 355 carb'd
I think I know why if you have an MSD box..... If so and it's connected to a non MSD distributor- you will have to use the little itsy relay that came with it in the box. Once you put that in the MSD box everything will work right.
Old Apr 6, 2006 | 09:58 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Somethings feeding power back into the circuit, good luck electrical gremlins suck!
Old Apr 6, 2006 | 10:08 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I'm taking it that it isn't just plain old simple dieseling run on that happens with carb cars sometimes
Old Apr 6, 2006 | 10:41 PM
Hodge's Avatar
Car: 1987 IROC-Z28
it's not diesling. it's fully running. I could drive it that way if I wanted.
Also, the way I get it to turn off is by continually turning the key from on to off and eventually it takes it.
No MSD box either
Old Apr 7, 2006 | 06:42 AM
Car: 1986 Vert Z28
No MSD box either
ROFLMAO!!!!
Old Apr 7, 2006 | 07:07 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If your oil pressure switch is still present above the oil filter. Unplug it and see is that solves the problem.
Old Apr 7, 2006 | 07:15 AM
raptor.gta's Avatar
Car: 90 Trans am GTA
sounds like a short to me. if it is still running then somehow there is still current flowing through the ignition circuit and fuel pump. check all your connections and check your wiring that you did with your hotwire.
Old Apr 7, 2006 | 08:04 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
No MSD box either
if that turns it off chances are that should be your problem.
might just need to rebuild the lock if you can.
Old Apr 7, 2006 | 07:12 PM
Hodge's Avatar
Car: 1987 IROC-Z28
put a new lock in it today and it is still doing it.
Old Apr 8, 2006 | 11:50 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
IT's BECAUZ YA JUS CAN'T SHUT US CAMAROS DOWN
<CENTER><B>
Because you rewired it and it was working for three years the problem is
a short or stuck relay in the ig. circuit. Possibly a wire insulation rub
thru. You must trace it manually to find where it rubbed. </FONT>
</B><FONT COLOR=F3399><H5>
“If people drove any slower they’d be going backwards.”</FONT>
<FONT COLOR=FF66FF>NINÅ</H5></FONT>
<P>
<TABLE BORDER=9 CELLPADDING=8>
<TD BGCOLOR=black>
<B><H3><CENTER>REFUSE
TO
LOSE<p></TABLE></CENTER>
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
Jae992
Aug 27, 2015 09:07 AM
