Starter for 153 tooth flywheel 2 piece rear
Old Apr 10, 2006 | 05:37 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
Hey I am doing the T5 swap with a goodwrench block 2piece rear
The starter I got from autozone didnt work out it used the 1 long
1 short bolt to hold it to the block.
The starter bolts I found at the help secition where to long so I tried
to use about 3 washers then when that didnt work I put the washers on the block side of the starter to try and get it right.
I thought I could use any starter for 153 flywheel any ideas?
I am going to look for starters that have straight across bolt patterns
I guess.
1992 Trans Am
May 10, 2023 07:19 PM
mhatfield 14
Oct 24, 2015 07:48 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
milk
Aug 10, 2015 06:26 PM
