Gauge wiring question...
Old Apr 10, 2006 | 02:49 PM
LWillmann's Avatar
I'm getting a 1991 Firebird V6 that doesn't run, and am planning to swap a V8 into it.
I'd like to just drop a standard carbed SBC into it, no computer controls, maybe a T-5 transmission, with a 3.42 4th gen rear.
How are the gauges set up in the 1991 Firebirds? Are the speedometers mechanical or electrical, what will I have to do for things like the tach, and other gauges?
Old Apr 11, 2006 | 03:05 AM
Firebat's Avatar
Speedos are electric from at least 1986 to 92 on firebirds. Probably keep the computer for the speedo. I'd recommend swapping a whole V8 140MPH/8000RPM cluster from a 85-92 T/A. If you never go above 6000 RPM then swap in a 6000 rpm V8 tach.
A V8 needs a different tach and oil pressure gauge.
Old Apr 11, 2006 | 08:03 AM
LWillmann's Avatar
Thanks for the reply. I'm considering other options as well. I totalled my 96 Formula, and have been parting it out. I still have the engine, harness and PCM and am considering swapping that into the 3rd gen car.
Old Apr 11, 2006 | 11:30 AM
Firebat's Avatar
the Lt1 will work with thirdgen V8 gauges.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
