tach signal wire
Old Apr 10, 2006 | 03:39 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
tach signal wire
I was wiring in an aftermarket tach that I had lying around, it worked a couple of years ago. I'm having trouble, when I put power to the signal wire the tach doesn't move. Is this normal, I don't think so, it should go to the max rpm correct. It's an autometer tach with 4 wires. One is red, white, black, and green. I have a good ground and it's wired up the same way it was in my last thirdgen. The green is the signal. I'm lost, even when I put power to the white wire for the stock tach, it moves a few hundred rpm and that's it. This made me think i'm doing something wrong.
Wiring isn't my strong point, i'm also having trouble with the speedometer wiring.
Old Apr 10, 2006 | 05:21 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
I still can't figure it out, i'm not worried about the stock gauge. I just want to find out if the autometer gauge should be pinned when voltage is supplied to the signal wire. I'm using a power probe, that works fine.
Old Apr 10, 2006 | 05:34 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
i think........the white is the sig wire and the green is what you hook up to the switch so it lights up when your lights are on
Old Apr 10, 2006 | 05:41 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
The tach signal is usually green. the red and black are power and ground and the white is for the light.
Old Apr 10, 2006 | 05:42 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
It's been years since I have messed with one but I think the white wire is the signal wire and the red wire is 12+ ignition...
Old Apr 10, 2006 | 07:41 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
I hooked it up the way it was used in my camaro, and I looked on the autometer website. The green is definitely the signal, and the white is for the gauge light. I just don't know if the tach should be pinned when I apply voltage, I think it should. I don't have a motor in the car yet, but this drove me crazy today. I don't know if the tach is any good. Does anyone know?
Old Apr 10, 2006 | 08:40 PM
Engine: 355 chevy
why dont' you call autometer and maybe they can help? lol just a suggestion since they do make them.
Old Apr 10, 2006 | 08:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No it shouldn't pin the needle, the tach signal isn't PWM.
Old Apr 10, 2006 | 08:50 PM
Engine: 355 chevy
ditto thats what I was thinking.
Old Apr 10, 2006 | 08:53 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
thanks for the response, and clearing it up for me. It was a simple question, I could've called the company, but I thought i'd check on here. The weird thing was if I ran the power probe over the signal wire without applying voltage or ground it jumped, this got me thinking it didn't work off of straight voltage.
if ur going to be sarcastic why post?
What's PWM?
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
