serpentine swap alternator q's (searched) please HELP
Old May 2, 2006 | 10:02 AM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
hey guys i have like the title says done a serp swap into my 84 z any way just wanted to see if in all my readign i have found the best way of hooking up this cs130 typre alternator
s terminal (10gauge?) this goes to the batt terminal on the back of alternator
L terminal this gets 12v dc switched and there are conflicting reports as to weather or not there need to be a resistor inline
f terminal this one goes to the black / brown wire that goes to my voltage guage in the dash
does this sound right??
please i need to get this right so i can drive the new 350 that went in at the same time haha
steve
Old May 2, 2006 | 10:18 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
there should be a wire on the back of the alternator going to the battery with a fusible link, then theres either a 2 or 3 wire black connector, 1 big red wire should go to the starter terminal, then there is a brown wire that goes to the electric fan relays/battery gauge, sometimes theres a tan/wht wire that i hear does the same thing as the brown wire.
Old May 2, 2006 | 11:05 AM
1984HO's Avatar
Car: 1984 Z28
do you happen to know which terminal exactly goes where??
s, f, l, p,
those are the terminals they are labeled on the connector
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
