tach. bounce/mis...ok with EST unplugged
Old May 2, 2006 | 08:59 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
ive had this problem for awhile now. with the est wire plugged in, the tach will jump up only about 100 rpms, with no change in sound. when i drive lighly or on flat ground its ok, but as soon as i step on it or go uphill, the tach drops and twitches and the car boggs and misfires BAD, i unplug the EST wire, and everything is perfect other than lack of proper timing. the distributor was rebuilt 2-4 months ago, has new cap/rotor/wires/plugs/jegs 49,000 volt coil. there is a loud loose change like clicking noise, but only under a good load, i also have a code 34 for the MAF, would this cause it, ive had this code for many months with no problem, its a new MAF. could that noise be my dizzy is shot, like a bad bearing or somthing...
Old May 2, 2006 | 09:33 PM
Brads RS's Avatar
check your est wire, make sure that there are no cracks or insulation missing causing it to short out. From what you are describing that sounds like whats happend.
Old May 2, 2006 | 10:15 PM
Car: 1986 Firebird
thanks, now that i think of it, i remember seeing a worn down bare wire back there somewere, ill let you kow how it goes when i get to it...SOMEDAY
db057
Apr 28, 2019 07:45 AM
L98GTA87
Oct 19, 2015 10:43 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
pacoelrapido
Sep 11, 2015 02:41 PM
