someone please answer my question!!!!!!!!!
Old May 2, 2006 | 09:33 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
all i need to know is this
im installing a cs130 along with the serpentine setup in my 84 z which origonaly had a si type alternator
all i want to know is how do i install it so that my volt gauge in the dash still works and i dont fry the alternator
so basicly can i put a 35-100 ohm resister in that wire from the gauge and then connect it to the alternator at the "L" terminal is that right?
please all i need is to resolve this and i can drive it with the new engine
AHHHHHHHHHHHHHHHHHHHHHHHh
thanks steve
Old May 2, 2006 | 09:53 PM
Brads RS's Avatar
what style gauge do you have? (voltage or charge no charge). I'm not clear on the style alt that you have, does it have two wires (from volt. reg) and one to the battery? give me a little more info and i might be able to help. I rebuild alts wire streed rods for a living
Old May 3, 2006 | 11:44 AM
1984HO's Avatar
Car: 1984 Z28
i have a volt gauge (reads 8 13 16 volts etc...) and my old alternator was a si type two wires one to the battery terminal on the back of the alternator and the othe went to a bloack wire that was on the ground side of the volt guage and im trying to install a cs130 type alternator wich has 3 terminal 1 to batttery post on alternator one istn't used and one that i think goes to the black wire but from what i read it needs a 33 ohm resisitor to decrese voltage to the alternator
Red iroc-z 305
Sep 30, 2015 05:22 PM
TEEZER TA
Aug 30, 2015 06:35 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
