How to remove alternator drivebelt on v belt model cars
Old May 4, 2006 | 02:30 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
I'm having trouble removing the alternator drivebelt on my car, it is a v belt. I know this is a simple question, but I can't seem to get it off, I tried using a wrench and removing the belt blocking it, but it simply twists and moves like it should. Can anyone tell me how to remove this belt, thanks.
rjpbboi - Photobucket - Video and Image Hosting
P.S. I know I need a new camera, the battery keeps dying so I can't use any focusing features
Old May 4, 2006 | 03:53 PM
jeremys82c10's Avatar
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
Axle/Gears: 8.8 w/3.08's with a trac-lock
did you loosen the mounting bolts, and try to push it, try that
Old May 4, 2006 | 06:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Loosen the alternator pivot bolt on the bottom slightly, loosen the bolt in the slot on the bracket at the top, rotate the alternator and pull the belt off.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
RazorN8
Jan 7, 2022 11:44 AM
3rdgenparts
Aug 8, 2015 07:09 PM
