Daytime lights always on
Old May 4, 2006 | 05:04 PM
gt500pwr's Avatar
I've got a '91 camaro RS and when I turn on the car the lights come on, but it doesn't happen all the time. Under the dash pad is a sensor for the daytime lights so when it doesn't happen, if I put something over the sensor the lights come on then if I remove the lights go off. Trouble is it's intermittent. Can these sensors be replaced from a regular parts store or dealer product only?
Old May 4, 2006 | 05:51 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Your car was originally sold in Canada and has factory Daytime Running Lights. Cut a hole in the dash pad for the sensor to look through. I'd suspect a replacement would be a dealer only item.
Lon
Old May 4, 2006 | 06:03 PM
gt500pwr's Avatar
Theres already a cut out for the sensor so i guess i'll check with dealer.
thanks
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
