Check Engine Light Not Working
Old May 5, 2006 | 01:15 AM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
On my 91 camaro rs the check engine light doesnt come on at all, not even on ON position. and also i maybe wrong on this but is pin d on the aldl connection the one for codes or pin b and a? because if it is pin d im missing it. Thanks Martin
Old May 5, 2006 | 06:57 AM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
Transmission: 700R4 TCI performance
Axle/Gears: 10 bolt disc brake 3:42 slp auburn
It is pin A and B. Pin B is the power and pin A is the data
Old May 5, 2006 | 11:16 PM
Brads RS's Avatar
pin a is ground, pin b is mode select, pin e is 8192 data, and pin M is 160 data. But for testing you just jump across a and b if you have a 90-92 and 85-89 you jump with a 10k resistor across A and B.
Old Jun 19, 2006 | 12:34 AM
1Bad3rdGen's Avatar
Engine: 305 L03 TBI
Axle/Gears: Stock
i been trying to solve the problem but cant figure it out. sometimes the check engine light comes on with the key position on (engine not running) but most of the times it doesnt come on. and the other day i tryed to pull the codes and the onling thing that would come on is the brake light and thats it. do i have a loose connection or something?
Martin
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
