interesting starter problem
Old May 6, 2006 | 10:11 AM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
ok i have an 86 iroc, just put my 350 in it hooked up the started on what i thought was the right way. there are 4 wires. 3 red and one purple. judgeing from my 83 the purple, and two of the red ones were at the positive stud on the starter. i hooked up power went inside and i had nothing. no dome light no power locks nothing. turned the key to the ON position i have power to everything and the starter turns over. turn the key back to lock and no power anymore. i switched some of the red wires but all i got was constant power all the time, didnt matter where the key was and no starter. i was told it could be the ignition relay in the column? so short from taking the column apart i am at a loss. any ideas? thanks
Old May 6, 2006 | 04:05 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
The starter on our cars has 3 terminals. It doesn't have a ground terminal because it grounds through the engine block and thirdgens only use 2 of those 3 terminals. Basically, that purple wire goes to the S terminal while the other terminal acts as a B+ for starter and also a junction box for other wires. Fix your wiring and report in.
Old May 6, 2006 | 09:39 PM
nascar2496's Avatar
Engine: 305 tpi
ok so your saying that purple wire is the starter ignition wire? and the rest should be on the positive post? now the only reason i did not try that is because my 83z has the purple wire on the positive post or B+ as you said. But i will give it a shot tomorrow, Thank you for the help.
Old May 7, 2006 | 06:07 PM
nascar2496's Avatar
Engine: 305 tpi
ok well i put the purple wire to the starter and all the rest to the positive..everything is on before i turn the key, starter turns over in the correct spot but again there is no off position and when i tried to use the window the choke light came on when pressing the switch and off when not. so i dont know what to do except get it running and driveable and take it somewhere
Old May 10, 2006 | 09:49 AM
nascar2496's Avatar
Engine: 305 tpi
ok after about 4 hours of wire tracing and testing different wires this is what i found. the previous owner had some pos remote start in the car...wierd considering it was originaly a manual, and that pos was a whole mess of different wires, removed it. still nothing. so i checked the fuse box there was a wire that ran from the gauges fues to the ACC fuse...checked on my other car it didnt have one so i cut it and now everything works the way it should.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
