not working, int lights, cig lighter.
Old May 6, 2006 | 10:26 PM
bahsarie's Avatar
Car: 89 IROC-Z T-top C&C
my map lights and dome light dont work as well as remote trunk release? is it a fuse and if so which one is it? id appreciate the help also is it a 5 , 10, or 15 thank you ahead of time!
Old May 6, 2006 | 10:31 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
just grab a test light nd start checking, probably the easiest way. None of my cars still have the markings on the fuse box's.
Old May 7, 2006 | 07:22 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
yep fuse
i forget which one ,but the cigarette lighter,dome light,rear hatch pull down motor are all on same fuse,seems as if a 20a hot all time fuse
Old May 7, 2006 | 09:09 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Should be a 20 amp fuse right next to the power window breaker (silver plug-in can), assuming you have power windows. Counting from the top left (ECM fuse), should be 3 over and 3 down.
From my owner's manual (1992) should be similar.
Old May 7, 2006 | 10:58 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
What has this world come to when we have to ask about checking a fuse
jaridjohn
Jul 8, 2024 03:49 PM
ezobens
Aug 19, 2015 10:29 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
