Lights flickering
Old May 10, 2006 | 12:17 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
Lights flickering
My lights flicker at idle and less while running. Last I checked (about 2 months ago) my Alt. belt was tight. Since it flickers with the rpm's of the engine. I'm wondering if there is something more serious thats internal. Can its still be the belt? Would it make a diffrence if it was super tight or less then a 1/4 inch of play? Or can it be something else?
Old May 10, 2006 | 08:53 PM
GameRS's Avatar
Car: 1990 Camaro RS t-top, '01 BMW 325i
Engine: L03 V8, 2.5L I6
Transmission: 700r4, Steptronic 5-spd
Axle/Gears: stock, stock
It's probably a ground wire that's loose, and since the engine vibrates the whole engine bay, the wire does too, along with its rpms.
Old May 15, 2006 | 10:24 AM
phoxetis's Avatar
Car: T/A
Engine: 5.0 v8 TPI
last time I had that my alternator was dying. It turned out that some fluid was busy destroying the electronics. After it died, I found out. I think it was only partially working for a certain time and thus causing the flicker
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
