voltage level at idle (750 RPM)
Old May 12, 2006 | 09:41 AM
myfirstchevy's Avatar
Car: 87 camaro sport coupe convertible
Transmission: auto
I have an 87 Camaro convertible with a 305 automatic.
Looking at the Volt meter (in the dash), I get 13 V when I am at 1000 RPM or above, but it drops down to battery voltage when at idle.
Is this normal ?
Old May 12, 2006 | 11:05 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Not unusual, but it's really best to check with a meter at the battery. The stock dash volt meters are not at all accurate. Check it right, you may not be falling all the way down to battery voltage.
Old May 12, 2006 | 03:15 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
do you have underdrive pulleys?
Old May 15, 2006 | 08:43 AM
Transmission: auto
No I have stock pulleys.
But I also have a rough idle, which I was suspecting could be related to the low voltage. But maybe it is the rough idle that is causing the low voltage.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 23, 2015 12:52 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
