Pop up headlight alarm
Old May 13, 2006 | 04:45 PM
87pontiac's Avatar
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
Im just curious about a wiring issue,I would like to have my headlights pop-up when the alarm comes on and go back down when the alarm is off.Any good ideas would be sure nice.
I have a 1987 Firebird,with the 2-wire motors.
Ron
Old May 14, 2006 | 05:16 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
THIS IDEA POPPED INTO MY HEAD
Originally Posted by 87pontiac
.........I would like to have my headlights pop-up.............
You can tap into the wire that goes to the headlight switch
with one of the “hot when sounding” wires from the alarm
thru a time delay relay. The time delay relay will
prevent the light doors from closing before the event is over.
“If people drove any slower
they’d be going backwards.”
NINÅ
Old May 14, 2006 | 05:19 PM
GTA_IN_T.O's Avatar
correct me if i am wrong but then they will flash like your parking lights would.....and thats no good .........your headlights motors will be going up and down, cant see the motors enjoying it too much
Old May 14, 2006 | 05:40 PM
fadetoblack's Avatar
Car: 1990 Formula
Engine: 383 Stroker
All you should have to do is wire in a standard (doesn't have to be time delayed) 30 amp relay. Tap off of the siren output wire (the siren output is a steady output, not pulsed) to use as the trigger for the relay; terminal #85. Connect terminal #86 to ground. Connect terminal #30 to a strong +12 volt source. At terminal #87 (NOT #87A) first connect a diode. Then run a wire from the other side of the diode and tap in to the positive output of the headlight switch. *** NOTE: THIS WILL ALSO CAUSE THE HEADLIGHTS TO COME ON; POSSIBLY CAUSING A BATTERY DRAIN IF THE ALARM IS TRIGGERED MULTIPLE TIMES.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
