Horn Wiring help
Old May 13, 2006 | 08:46 PM
ryane88's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Horn Wiring help
ok wire from steering wheel to column is black
what color is the wire... i need to find it somewhere bw the column and the relay
Old May 13, 2006 | 08:51 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i believe it is a yellow wire, atleast it is on my car, i would assume that you have an aftermarket steering wheel.
Old May 13, 2006 | 09:00 PM
ryane88's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
ugh
still can't find that stupid wire
been looking for like freaking 4 hours and i all i need to do with it is splice it be4 the relay... FIVE minutes
grrrr
i think i am going to run 14 aug wire from the accessory battery cable with a fuse... to the relay that comes with the horn..(with this setup, i should have a hot lead right?) ... wire the compressor to the relay, the 14 aug from battery, ground the relay, and the compressor, then i'll get a horn button from advanced and find a place to mount it...
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
