Come:help:Wire My MapLights Please...
Old May 14, 2006 | 06:48 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
i just got a free domelight cover with 2 map lights. i am guessing my rs didnt come with extra wiring. so i wont have the connector like the iroc it came from. i want the 2 map switches to be hot all the time; not just with the key on or only when the dome is on for obvious reasons. i came up with:
a) running wire from my fuse box to the lights and another to a grounded screw. would i use a slot not being used or could i wire into my headlight or taillight fuse? (not sure how to do this one)
b) this may not be possible. do i have constant 12v to the dome light? (im pretty sure i dont) if i do, i could splice into its +wire and the other to ground/-wire. right?
c)whatever you guys think... haha i dont know a lot about electronics, only thing i wired was my head unit and amp.
thanks for reading
Old May 15, 2006 | 04:59 PM
Firebat's Avatar
option b might actually work. If i remember right, the switches for the doors open/closed to turn on the dome light, connects/disconnects ground from the circuit. That would mean you have a constant 12V going to the dome light.
Old May 15, 2006 | 08:00 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Firebat you have it right.Almost,if not all GM products - well up to '91,accessories are hot and it's ground connection is broken to turn it off ie;radiator fan relays,interior lights among others.
Old May 15, 2006 | 08:55 PM
Car: 89 camaro rs
Engine: 305 tbi
awesome news guys. so i could use my multimeter with the doors shut and test for a hot side? then splice my map lights' hot to it, and screw the other wire to my t-top bar for a ground?
also, how important is it on these lights to be wired correct? (will it hurt to have the wires backwards?)
Old May 15, 2006 | 10:01 PM
Firebat's Avatar
Doors open or shut, the wire with 12V will always have 12V. (if everything is wired right of course).
The 12V wire is probably going to be orange/red/yellow or some other color. The ground wire will probably be white or black.
If you hook it up wrong, you could either blow a fuse or nothing at all would happen if you connected ground on both sides. Maybe.
Is this the overhead console? I have one console waiting to be installed and have the wiring on it. I can tell you how its wired. If its the overhead console, one switch is for the dome, one is for the map light.
Old May 16, 2006 | 01:16 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I got the same unit and was wondering if anyone has done this. Do we have to cut/trim the headliner? If so, could someone post a diagram with the deminsions of the headliner to be removed.
This might help for you overhead console guys Overhead Console Installation
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
Doward
Oct 3, 2005 08:07 AM
dual_88s
Mar 9, 2004 06:13 PM
ChicagoTransAm
Apr 4, 2003 12:17 AM
HT 1985 IROC-Z
Jun 22, 2001 03:09 PM
