Low volts, whistling alternator
Old May 17, 2006 | 10:12 PM
thefightback's Avatar
Car: 86 Z28
Engine: '90 350 TPI
Transmission: T700
my camaro has "whistled" since i have owned it - a bit over a year now. I was told by a mechanic it is the alternator. recently i used tuner pro to have a look at a few things and saw my volts are pretty low. at one point during idle, they dropped down to 7.5 for a split second then back up to high 11s. whilst driving the volts are at high 12s to low 13s which ive read is far too low.
the only thread ive found with similar problems is here:
https://www.thirdgen.org/forums/elec...ighlight=volts
but there is no solution. can someone please help me out?
Old May 18, 2006 | 12:47 PM
Firebat's Avatar
Never heard of a whistling alternator. I'd try swapping batteries with another car first, but it will probably do the same thing. Its probably the alternator gone bad.
Old May 18, 2006 | 08:16 PM
Car: 86 Z28
Engine: '90 350 TPI
Transmission: T700
well i got the multimeter on the battery last night and tested it. looks ok now at idle - 13.9 volts. can tuner pro sometimes give false readings? or maybe the volts arent getting to the ecm?
Old May 18, 2006 | 09:16 PM
zrated57's Avatar
Is there an idler pulley anywhere on your belt set-up? My buddy had a noisy tensioner/idler pulley on his car and it whistled like a supercharger. Sounded a bit mean actually.
Old May 18, 2006 | 10:19 PM
Car: 86 Z28
Engine: '90 350 TPI
Transmission: T700
yeah mine sounds a bit like a super charger too. many people have joked about it. as long as there is nothing really wrong with it i dont mind the noise.
now i just gotta find whats causing this bastard code 54 on start up intermittently
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Jlanz55
Sep 6, 2015 03:05 PM
Glowsock
Sep 6, 2015 06:40 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
