Oil pressure guage
Old May 19, 2006 | 09:59 PM
dacboyz's Avatar
Car: 89 Camaro
Oil pressure guage
My oil pressure guage doesnt work. Any ideas why or how to fix this?
Old May 19, 2006 | 10:17 PM
jsel's Avatar
Car: 1989 iroc conv
Engine: L03 TBI
Transmission: 700R4 soon to t5 from hawks
make sure the sending unit is working and check the wires go to the unit
Old May 29, 2006 | 09:21 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
what's does it read
When the car is running, what does the oil pressure read? Is it flat a zero or is it pegged all the way over?
Old May 30, 2006 | 02:32 PM
dacboyz's Avatar
Car: 89 Camaro
Its pegged all the way over and then some so it seems.
Old May 30, 2006 | 05:29 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
Well, it can be one of 3 things, Bad Gauge (not likely), Faulty Sensor (possilby) or just a bad ground (very likely). I would work in those directions.
The most likely is a bad ground. If you connect a test light to the plug that connects onto the oil pressure sensor, should be a single wire plug and ground the connection to a good solid ground, the light should come on with the key in the on position (not run). The next thing I would do is to remove the sensor itself, most of these are about the half size of a 12 oz soda can and can be a pain to get to depending on how it's mounted. Connect an wire to one end and ground the wire. Then run a wire from the plug connector over to where it would plug in on the sensor. If the wire now has a good ground and the sensor is good, the gauge should read at zero. If not, then you may want to try a replacement sensor, which you can test the same way before installing it. If your old sensor is good, then your problem is simply a bad ground. I would start by cleaning the connections at both ends of the relay. Some people make the mistake of using teflon tape on these, which is not necessary and can prevent the sensor from achieving a good ground.
These are the steps I took 2 days ago after having the exact same problem. It turned out to be a bad ground...
Good luck,
Old May 30, 2006 | 06:07 PM
dacboyz's Avatar
Car: 89 Camaro
Thank you for your info. Sounds a little complicated for me. Any pics or diagrams for this. Thats usually a little easier for me especially being a female.
Old May 30, 2006 | 06:13 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
It only sounds more complicated than it is... I will see what I can do.... If you don't have it figured out by tomorrow, I'll have some pics for you.
Old May 30, 2006 | 06:34 PM
dacboyz's Avatar
Car: 89 Camaro
I wont have time to look at it until later in the week so pics or whatever would be greatly appreciated. Thanks.
Old May 30, 2006 | 07:52 PM
86birdHT's Avatar
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
My Gauge doesnt work either, as its pegged past 70psi. There is a connector just chillin there by the oil filter, and when i had it up on my friends lift i checked that area and theres 2 places it COULD be plugged into, but they have metal plugs in them right now, and there is no provision up by my distributor, just another plug.
Old May 30, 2006 | 08:15 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
what kind of engine setup are you running?
Old May 31, 2006 | 02:25 PM
dacboyz's Avatar
Car: 89 Camaro
Its the factory v-8 305 tbi.
Old May 31, 2006 | 10:11 PM
xandersdad's Avatar
Car: Now Camaorless
I had the same problem with my 86 305, no oil pressure. I took the sensor out and hooked up a mechanical gauge just to sure I did have pressure, pressure was fine. I took a sensor out of another engine and tried it it work somewhat but then quit, so I put a mechanical gauge back in it and just mounted it under the dash till I get a new sensor. At least I can see my correct oil pressure.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
