New ignition wiring
Old May 22, 2006 | 09:37 PM
Zrunner90's Avatar
Car: 1990 Camaro RS Ttops
Engine: 89 IROC 305 TPI
Transmission: M5
Axle/Gears: 3.23 limited slip
New ignition wiring
Due to a recent attempt by someone to steal my car, ive decided to redo my entire ignition wiring since the theif busted out part of my steering column, and breaking the little clip that connects the lock cyinder to the rod that moves the regular ignition switch. Ripped apart a spare one i had, figured out what connects to what for on, acc, and start, wired it up with a new keyswitch, and a push button start, plus a couple toggle switches, but all that happens when i go to start the car is i hear a little relay on the kickpanel switching but the starter does nothing. I hooked the wires back into the regular switch and used some pliers to push the rod and it fired right up. So does anyone have any suggestions on how to wire this up? Maybe a digram that shows what all the wires go to. I had all my wiring connecting into the harness so i didnt cut all the wires into a wire hell under my dash.
Any info is greatly appreciated!!!!!!
Old May 23, 2006 | 05:35 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I know this might sound stupid but are you bypassing the clutch start switch too? How about VATS?
Old May 23, 2006 | 02:06 PM
Zrunner90's Avatar
Transmission: M5
the vats is bypassed but im not for sure if the clutch switch is. theres a black cylinder thing on my ignition switch with a button in it that looks like it could be it...but when everythings hooked up like factory itll start whether the button in there is pressed in or not.
Old May 24, 2006 | 02:23 PM
Zrunner90's Avatar
Transmission: M5
Suggestions anyone? The help would be much appreciated
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
