Green wire with heat damaged connector
Old May 23, 2006 | 12:19 AM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
1988 IROC 305 auto to ZZ4 5spd. swap, I found this wire dangling during the swap and I can't find what it is supposed to connect to.
It was bundled with one other wire, the lead which attatches to the oxy sensor on the driver's side exhaust manifold.
It is a single green wire with a connector that appears to have some heat damage, also...there is a clip attatched to the corrugated wire wrap on this lead.
Any suggestions?
I can't seem to locate it on my POS Haynes schematics.
Old May 23, 2006 | 05:29 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Looks to be the temp sensor on the side of the head.
Old May 23, 2006 | 10:19 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Same here.Temp sensor wire on driverside head.In between the 1 and 3 spark plug.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
