MAP sensor wires
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
MAP sensor wires
Hello guys and gals,
I need help with the wire position on the MAP sensor. I need to know where does the signal wire, ground wire and power wire connect to the MAP. The MAP sensor has three letters A,B & C for wire connection, which is which?
Thank's in advance
Thank's in advance
9192camaro
16
Feb 3, 2019 12:21 AM
