temp gauge
Old May 26, 2006 | 11:25 PM
darrel88's Avatar
temp gauge
Well I have a problem with my temp gauge. It's stuck all the way up and won't come down. I've taken apart the cluster and took it down, but when I start the car it just does it again. Could this be a problem with the gauge?
Old May 26, 2006 | 11:31 PM
AJ89Irocz's Avatar
Car: 1989 Camaro Iroc-Z
Axle/Gears: 2.77 Posi
I had the same problem, my gauge was bad, got one on ebay for like 10 bucks, id say that is your best best, but i guess it could be your sending unit but ill bet its the gauge, just look on ebay for one or ask in the classifieds here. good luck
Old May 27, 2006 | 12:53 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
If the guage is pegged, check the wire to the sender. It may be grounded out on the exhaust or something.
Old May 27, 2006 | 07:29 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
When you start the car the temp gauge goes to max then comes back down(this is the correct movement).When you remove the gauge from the cluster does the needle move freely?The wire to the sending unit is grounded like bingo suggested.The sending unit is on the driver's side head between #1 and #3 sparkplugs and the lead is dark green.
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
