Relay longevity question
Old Jun 2, 2006 | 11:38 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I am wiring up a kill switch, which will use a relay to connect/disconnect the neutral safety circuit. Would there be any disadvantage of powering this relay from an ignitiion switched source, so the relay is always energized during normal driving? It will not be handling any current except for during cranking.
Old Jun 2, 2006 | 04:16 PM
Gymbeau's Avatar
I don't think I would wire it like that. I would go with a good, quality switch that is rated for the current during cranking. I try to only use relays where they are absolutely necessary. A switch is much simpler and more reliable, in my opinion.
I like the idea I heard about a long time ago where the switch is a push button type mounted in the bottom of the cigarette lighter. If the lighter is pulled, the car won't start. You have to push the lighter in to make the switch and get the starter to engage.
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
Bryan F
Aug 18, 2015 02:28 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
