headlight motor swap
Old Jun 4, 2006 | 11:51 PM
BanditMan's Avatar
Car: 84 trans am
Engine: 305 H.O. with small cam
Transmission: th350 with manual valvebody
Axle/Gears: 3:73's
are the motor assemblies with the 2 pin connectors swapable with the 3 prong connectors, cuz i need a new one for my right headlight. All thats wrong is the gear that the worm gear engages is stripped, but i cant find those anywhere, just the larger one.
Old Jun 7, 2006 | 10:23 AM
Vader's Avatar
Originally Posted by BanditMan
... All thats wrong is the gear that the worm gear engages is stripped, but i cant find those anywhere...
You didn't check the obvious places. Our friendly board sponsors have products specific to our vehicles, and it's always a good idea to check their offerings. Here's just one possibility from one sponsor:
Top-DownSolutions.com
If that isn't quite what you need, you may want to check with Lon at TDS. He may be able to source what you need.
Old Jun 7, 2006 | 11:57 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes you can swap the newer two wire motors for the inferior 3-wire motors (along with all the wiring and relays). The far better solution is to repair your 1987-92 2-wire headlight motor with either the TDS 207280 or TDS 209280 headlight repair kit. What goes bad with these motors isn't the large gear**, but what is inside the gear. There is a reason why you'll find so many of the older 3-wire headlight motors at the pick-a-part yard. You'll be way ahead if you let those motors rest in peace.
**The first time you repair them the bushings are what go bad. If someone has already replaced them with something else (ball-bearings, hex nuts, wooden dowels, **** leather, etc.) then the OD teeth of the gear can be bad. It's no problem if you discover that is the case for you, I also sell aftermarket gears TDS 504040.
Lon Salgren
Top-Down Solutions
Old Jun 10, 2006 | 02:00 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
the gear only moves 180deg you can take it out and turn it to the good side or they sell them on ebay eighther the plastic ones or you can spend about 40 on some brass ones that will never strip again you just gotta look man.
here is the brass one
ebay item number 8074286329
Old Mar 19, 2007 | 09:24 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
my driver side one i cant tell which half has been used and which hasnt it looks the same all the way around it no damage or differetn wear, or any wear at all, just is dirty, looks fine
how do you know which half was unused ??
thanks
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
st.evel07
Aug 13, 2015 06:15 PM
stalkier
Aug 13, 2015 12:59 PM
