Ignition BEEEEEEP and dash light problems. HELP!
Old Jun 5, 2006 | 08:09 AM
Rosadoc-Z's Avatar
Car: 1987 Camaro IROC-Z
Engine: 350 5.7 TPI
On my 87 5.7 360 IROC, the ignition beep (the beep that comes on when you stick the key in the ignition) stays on a for a really long time, probably a whole minitute after i start the car and drive it. It's pretty loud and annoying. Also, the lights in my dash (SES light, fasten seat belt, hand brake, etc) dont come on at all when i turn on the ignition. I'm thinking these two problems are related but I'd appreciate it if I can get help on at least fixing one them.
Oh and I've checked all the under the dash fuses. They are fine.
And I dont know if this is related but when i turn the car to ACC, the fan comes on. It happens all the time, being that i just bought this car, i was wondering if this sounds normal?
Old Jun 5, 2006 | 09:07 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Does the fan come on when you start the car? If it does, then it sounds like someone has wired to the fan to run constantly. As for the beep when you put the key in the ignition, that could be a bad ground or a bad audio alarm unit which is located in the convenience center. The convenience center is located under the dash near the drivers right knee.
Old Jun 5, 2006 | 09:50 AM
Rosadoc-Z's Avatar
Engine: 350 5.7 TPI
do you think a bad ground or alarm unit would affect the other issue, not having any of SES light, fasten seatbelt, parking brake, etc lights come on?
Old May 21, 2009 | 12:39 PM
Gilaad's Avatar
Car: 1992 Z28 G92
Engine: 350-245 (B2L)
Transmission: ?
Axle/Gears: G80
Re: Ignition BEEEEEEP and dash light problems. HELP!
My 92 RS has the same problem, I suspect a bad ground or similar electrical problem. I'm trying to decide which way to go with this problem. Any suggestions??
Old May 21, 2009 | 01:51 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Check your grounds.
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
