Severely hot wire, HELP
Old Jun 7, 2006 | 09:08 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
Over the winter I put an 94’ LT1 into my 91’ firebird. Recently I started having problems with the ignition. I had wired everything else but the starter to the ignition. The starter I have hooked up to a push button switch. Due to my recent problems with the ignition, I ran 30amp switch to the fuel pump as well as a 30 amp switch in line with a 30 amp fuse to the PCM using 14 gauge wire. The fuel pump wire and switch I am having no trouble with, but the wire, fuse, and switch inline with the PCM is severely heating up to the point that it is melting the plastic surrounding the wire. The fuse has not blown yet, but the wire is burning hot. Any advise is appreciated.
Old Jun 7, 2006 | 09:15 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
from my experience (not a whole lot but enough) when the wire got hot, either something was shorting or the wire was simply too small.. higher guage wire might do the trick and check for any loose wiring that might be causing a short.. also, before you start hacking at your wires, get more input from others on the situation first.. i may be wrong..
Old Jun 7, 2006 | 09:22 PM
Coach Hawk's Avatar
I forgot one more thing, the alternator is only charging at like 8 volts. Could this be another side effect of the faulty wiring of my switchs?
Old Jun 9, 2006 | 10:46 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
You are using wire that is too small for the application. I would have run 10 guage...maybe even 8 guage if you can easily do it. You are lucky that this hasn't caused a fire yet...
Also, check your grounds and make sure that you have a solid alt charging wire.
Old Jun 9, 2006 | 11:12 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
14-AWG is good for 15 amps, 12-AWG is good for 20 and 10 AWG is good for 30, nothing wrong with going bigger though.
stalkier
Aug 21, 2015 01:54 AM
Bryan F
Aug 18, 2015 02:28 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
