wireing gremlins
Old Jun 7, 2006 | 09:17 PM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
wireing gremlins
ok guys ive got two major problems here i think i know the answer to one of them but i wanted to run them by you guys.
#1 my radio and my interior lights both have no power. i didnt even think these two ran off the same circuit. but they both went out at the same time. i checked and did NOT find any blown fuses. could the relay in the convienence center under the dash have blown out?
#2 we wired up my dual fans with a switch and now they wont turn on. when i try to power them up it blows the gauges fuse in my fuse box (because i have it conected to the acc port underneath it. so it seems as if there is a short somewhere. ive looked at all the wireing and id otn see anything that could be wrong. the only other thign i can think of is possibly an internal short in the switch it self. it was working fine last night and it just stopped working when i went out to start it tongiht.
Old Jun 9, 2006 | 12:14 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Are you using a relay for the fan operation?
Old Jun 9, 2006 | 09:18 PM
tagta189's Avatar
Like he said,those fans draw WAYYY too much current to be drawing it through the acc fuse.You will need to run it thru a relay with a much bigger fuse straight from the battery.
Old Jun 10, 2006 | 01:35 PM
F-Bobby's Avatar
thanx guys yeah i realized that when i lookedat the cooling and heating fans circuit and saw that it had a 15 amp fuse in it ntoa 10. and the radio and int lights are on the same fuse and it was blown i guess i just missed it. i hate not having a test light at my house .
Old Jun 12, 2006 | 09:34 PM
xandersdad's Avatar
Car: Now Camaorless
Originally Posted by F-Bobby
....... i hate not having a test light at my house .
I have made a test light out of an old park light bulb and socket or a side marker bulb and socket. A little primitive but works when you don't have a real one.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
