Coil Resistance
Old Jun 19, 2006 | 04:03 PM
citydragon's Avatar
Car: Z28
Coil Resistance
1986 Camaro 2.8 MFI
I have no spark, I tested the ignition coil with a multitester, on primary resistance, I got a reading 0.0 ohms, the manual states it should be approx 1.0 ohms-(if higher replace the coil).
On the secondary resistance I got a reading of 11,600 ohms, the manual states between 4,000 to 10,000 ohms (if above 40,000) replace the coil.
If primary resistance is below 1.0 ohms (my reading 0.0 ohms) and secondary resistance is just above the range but not anywhere near or above 40,000 ohms does this mean a bad coil??
Can someone add some clarity to these readings for me. Thanks
Old Jun 19, 2006 | 06:39 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Looks like the coil is OK. It's hard for a run of the mill DMM to be anywhere near accurate at that low a resistance. The 11,600 is a little high, but not so high that you would get no spark.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
apie2546
Oct 16, 2016 02:24 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
