how do you test a MAP/ pressure differential sensor?
Old Jun 19, 2006 | 07:43 PM
xandersdad's Avatar
Car: Now Camaorless
I'm getting a check engine code for the pressure differential (MAP) sensor. I have an 86 with a computer controlled carb and 305. I need to know if there is a way to test/check this to make sure if it's the problem or something else. Any suggestions on doing this?
Old Jun 19, 2006 | 08:04 PM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
I could be wrong, but I believe you tap on the map with a screw driver while it is running. If it stumbles, it's bad.
Old Jun 19, 2006 | 08:08 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I know that that is the trick for MAF sensors... I have no idea about MAP though.
Here you go- https://www.thirdgen.org/forums/tech...ing+MAP+sensor
92camaroJoe
Jul 29, 2023 07:57 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
92camaroJoe
Aug 13, 2015 06:07 AM
