Fuel Level Sender Wires
Old Jun 21, 2006 | 09:02 PM
HELL0NWHEELZ's Avatar
Car: 1982 Z/28
Engine: 1968 302ci SBC
Transmission: TH-350
I just ordered some new in dash gauges, I ordered 0-160 electronic Speedo, Tach, Oil Psi, Water Temp and Fuel level Gauges, they are the Cockpit Series from VDO. Can anyone tell me what color wires and whether they are in the left or right plug for the factory gauges that comes from the fuel level sender.
Old Jun 26, 2006 | 01:05 PM
Car: 1982 Z/28
Aftermarket Fuel Level Gauges
If you install an aftermarket fuel level gauge that uses the stock sending unit (0 ohms empty and 90 ohms full) the proper wire to tap coming from your stock sending unit is the SOLID pink one located on the right plug for the stock gauges. There are quite a few pink wires with stripes on them so make sure the one you tap is solid pink.
jklein337
Sep 19, 2018 06:23 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
penguinpanda0
Aug 15, 2015 06:45 PM
