cluster panel bulb replacement
Old Jun 23, 2006 | 02:27 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
I KNOW its been discussed sooo many times here,
I ed the **** out about it in this forum.
what I dont understand is.. how do ppl know each bulb is what type,
like 168 184 194 and so on?
Im trying to convert my stock bulb to possibly a blue LED bulb,
and I just dont know what type of bulb to look for,
my car's a 91RS v6,
and I have a grant steering wheel so taking the cluster out is easy as hell.
but as for which bulb to look for, I couldnt find a blue bulb in autozone.. and I do see some, but they dont look similar and Im not sure if its compatible etcetc..
any tip is appreciated, thank you!
Old Jun 23, 2006 | 05:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The number is stamped on the bulb.
JamesC
Old Jun 23, 2006 | 05:44 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
but they aren't always easy to read. Also, you probably want this moved to the electronics forum, not fabrication.
Old Jun 24, 2006 | 02:59 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I used 194 LED replacement bulbs in my 91 dash. Jeese not that hard to answer a guys question.
Old Jun 24, 2006 | 08:26 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
go to napa they can order the blue bulbs for 10 dollars for 10 bulbs auto zone is much more money. i was looking into this when i had my 91 rs but i never did it.
Old May 7, 2007 | 01:48 PM
Rallysport91's Avatar
Re: cluster panel bulb replacement
Go to www.superbrightleds.com, they have a lot of direct replacment leds for out dashes and other vehicles. The also have serveral different colors to choose from.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
