Alternator or battery..?
Old May 7, 2007 | 04:20 PM
haxmire's Avatar
Car: 1987 350 swap
Recently I got an 87 305 Carb for myself. Well I was driving the other night and it died on me with my headlights and radio on. Well I found that I had a blown fuse and found a wire which looked like was giving me a bad ground. I replaced the fuse and wrapped the wire and all seemed to be fine. The car did not bog down and want to shut off with the lights on going up my street.
So last night I was going to have to run to the store and decided to take the Camaro because it was a nice night and I already had the T's off. Well I was going up the street and had my lights on and it started to bog down and wanted to kill the engine on me again. It didn't but I didn't want to risk it and keep going.
I was wondering what could be causing this? Is it a bad alternator or battery or what? The alternator in the car is brand new. I checked the batter voltage and it was good. I guess the alternator could have a flaw. Any ideas would be good.
Old May 7, 2007 | 04:22 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
Re: Alternator or battery..?
doesnt sound like either, whats your voltage read when crusing down the street? if its 13-15 its not either.
Old May 7, 2007 | 04:25 PM
haxmire's Avatar
Car: 1987 350 swap
the gauge jumps around when some electronics are on actually. when my blinker is on it moves up and down :/ but it is between 12-15ish
Old May 7, 2007 | 04:52 PM
j dezzy's Avatar
Car: 87 TA
I had a simillar problem with my 84 TA. I'd be sitting at a redlight or something at night with the lights on, then suddenly the rpms would drop, all the lights would dim...turned out that my alt was bad. you could take it to autozone and have it bench tested. only takes a few minutes.
Old May 7, 2007 | 05:25 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
If you have a DMM, you can test the alt yourself.
Let it warm up (some alts get worse when hot) and turn on most of the electronics in your car. Then, take a voltage reading aross your battery. It should be over or around 14 volts.
Next, switch the multimeter to AC volts and take a reading. You should get practically nothing. If you get any substantial voltage (1 volt or over), you might have a bad alternator diode that is letting some AC through.
The stock gauge is too inaccurate to trust. Don't use it, go by what the multimeter says. My stock gauge in my truck reads 18 volts when it is actually 14!!
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
