VATS Column swap
Old Jun 27, 2006 | 05:33 PM
olsteve's Avatar
VATS Column swap
Hello,
I am having a problem with a third gen firebird. The steering column was junk so I got a used one. After the new column was installed, the engine won't start. I tried using the resistor pellet from the old key and the new key. I did notice that there is one extra wire on the new column. It appears to be a ground but I am not sure what it goes to. I have also tried bypassing the VATS by using a resistor of the same value as the key (tried both resistences) placed in the unplugged connector coming from the ignition lock. I have no need for the VATS because it is a beater. Is there a simple way to get around this problem?? Any help is appreciated.
Thanks,
Steve O.
Old Jun 27, 2006 | 11:49 PM
ShawnPennington's Avatar
Car: 84 z28, 86 firebird, 91 camaro RS
Engine: 84 350,86 V6,91 305
A good friend from GM told me to take the resistance that is in the key and soder it in between the two white wires that go to the tumbler. It is a specific resistor for that ignition but sence you have changed the colum you would have to use the old resistor from the other colum.
Jorlain
Aug 24, 2022 05:11 PM
Street Lethal
Apr 30, 2019 12:14 PM
Out-Cast
Mar 22, 2019 09:39 PM
Pemberton76
Aug 15, 2015 07:15 PM
stalkier
Aug 13, 2015 12:59 PM
