my formula wont crank over with new motor?
Old Jun 27, 2006 | 06:33 PM
joel lopez's Avatar
Car: 1982 trans am
Engine: 406 small block
Transmission: turbo 350 with 2500 stall
Axle/Gears: 7.5'' hardened axels aurburn pro 3.73 gear
I bought a 89 formula with no motor or trans.The wiring harness that goes on the drivers side was also gone along with the computer. I also have an 82 with a bad body but good motor and trans. So I swapped out motor,trans and harness out of 82 into 89, and now It will not crank over. Everthing is hooked up like it was in the 82.This is all I need to get this 400+ hp bird on the road. PLEASE HELP!
Old Jun 27, 2006 | 11:52 PM
ShawnPennington's Avatar
Car: 84 z28, 86 firebird, 91 camaro RS
Engine: 84 350,86 V6,91 305
just a quick question did the car that you pulled the engine out of have the VAts system in it??? and are you getting power when you turn the key??
Old Jun 28, 2006 | 06:31 PM
joel lopez's Avatar
Car: 1982 trans am
No, it was an 1982 trans am. I had stripped it down over the years it was mostly a drag car. And the 89 formula came with out engine,computer,trans or under hood wiring harness. And yes, I am getting power when I turn the key.
Old Jul 4, 2006 | 02:17 PM
joel lopez's Avatar
Car: 1982 trans am
AH HA!!! I figured it out! After lowering steering colume I found ingintion switch. I then checked for power in start only spliced in to that wire( i believe it was the big yellow wire) and connected it to the N.S.S. and thats how I got around the VATS. This is a carb car so i dont think it will work for computer controled cars?
theshackle
Sep 17, 2020 08:26 AM
TheExaminer
Aug 26, 2015 04:59 PM
overdriv
Aug 20, 2015 03:52 PM
92projectcamaro
Aug 6, 2015 01:20 PM
