NO INTERIOR POWER
Old Jun 28, 2006 | 02:14 PM
CamaroSS_Black's Avatar
Car: 1986 Z28
Engine: L98 Block Vortec Heads Comp Xtreme
Transmission: Built 700R4
Axle/Gears: 10 bolt with Auburn 3.73 posi unit
NO INTERIOR POWER
bought an 87 sport coupe put a 350 in it runs power to the engine fine but the windows dont go down no lights or power on the climate controls but i do have my gauge backlighting only when i play with the dimmer checked all the fuses
Old Jun 28, 2006 | 06:33 PM
Vader's Avatar
Check Fuse Link A - It serves the PWR ACC circuit breaker, ACC fuse, TAIL fuse, and possibly some other circuits. Test for voltage on those fuses (should be present regardless of the ignition switch position). If those fuses have no power at either end, Link A at the starter may be broken. If that's the case, you'll have no horn, no interior lights, no headlights, no clock, no lighter, no hatch release, and no antenna power.
Old Jun 28, 2006 | 07:29 PM
Car: 1986 Z28
i have headlights dome lights horn and hatch release no windows lighter or defroster
Old Jun 28, 2006 | 10:05 PM
Vader's Avatar
Start checking at the junction block in the extreme left corner of the driver's footwell. Accessory power is distributed there, and there may be a connection/bussing problem there.
Old Jun 29, 2006 | 05:19 PM
Car: 1986 Z28
whats a bussing problem i dont really know anything about electrical
Old Jun 29, 2006 | 09:38 PM
Vader's Avatar
The junction block has metal foils between the various terminals which are connected there. These connections are usually crimped, and can fail with age. Checking the power at the ACC junction block with a voltmeter should reveal any problems.
Old Jun 30, 2006 | 12:40 PM
Car: 1986 Z28
hate to be a pain but can anybody post a picture i cant really take a picture to post it cause my computer is a peice of **** im sure its under a panel similar to the computer on the other side
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
diana227vegas
Jul 8, 2016 12:27 AM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
