'88 IROC Code 33 and 36 Problem
Old Jul 4, 2006 | 10:29 AM
senorcalvo's Avatar
After jumping the CCCS I received a Code 33 and Code 36 which would explain why my service engine soon light would't go off. After replacing the relays and MAF sensor(boy was that expensive!) the light went off and I thought I had solved the problem. Unfortunately after the car has been running about 10 minutes and heats up the light comes back on. If I stop the car and restart it it will go off but then come back on again after 10 minutes like clockwork. Sometimes it goes off on its' own when the car is running but itwill eventually light up again after some time. So I'm back to square one tring to figure this out! Does anyone have some experience with Codes 33 and 36 that might be able to point me in the right direction?
Thanks as always!
Mike
Old Jul 4, 2006 | 12:03 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
You will probably get more response on this in the TPI section. try posting over there.
Old Jul 4, 2006 | 02:55 PM
senorcalvo's Avatar
Will do-thanks!
M.L.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Fronzizzle
Aug 17, 2015 02:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
