Code 43 needs help
Old Jul 4, 2006 | 12:51 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Code 43 needs help
Hi!
I have just put in my new restored engine and its a speed denisity system.
When i first started it up i had idle at 700rpm and now suddenly no idle at all and it says code 43,i assume that it says ecm or nock sensor but i dont now where to start the trubbleshooting.
I have newer driven the car yet,just let you now.
Thanks for replay.
Old Jul 4, 2006 | 02:06 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok
I have run the engine for 10 minutes now and the idle are back so thats fixed,but still that code.
Old Jul 5, 2006 | 01:58 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Still having problem,the car runs best when cold but after about 3 minutes of driving it gets veak and not wery good idle and still code 43.
Thanks for any replays!
Old Jul 5, 2006 | 08:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your code 43 is for the Electronic Spark Control system. If you do a search of the board you will find where I have posted numerous trouble shooting charts for this code and many others. I bet it also knocks like crazy.
Old Jul 6, 2006 | 12:15 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Yes you are ded on it knocks badly,can you give me a link of were to start looking,chip,sparkmodule,knocksensor?
Thanks!
Old Jul 6, 2006 | 10:48 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok!
**** happends,i had been switching the nocksensor cable whith the fan temp pigtail.
So every theemes to be ok now,no codes anyway.
Just to let you now.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
