distributor engine mixing 86/87
Old Jul 4, 2006 | 05:55 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
I'll try to keep this short.
I have:
a new '87+ 350 B2L Long block.
a complete parts engine '90 305 TBI
a recently bought '85-'88 TPI with the '86 and earlier distributor (the big one) and wire harness.
can I put both of those (1 or the other) distributors on my 350?
did both '86-earlier and '87-later have roller cams or just '87-later?
will my '87-later distributor plug right into my '86-earlier wire harness?
if both distributors are usable, wich would be better?
are the gears of the distributor direct inter-changeable?
Old Jul 4, 2006 | 06:49 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
I believe 87 and older may have had roller cams,but I do not see why you cannot use either distributer.Look at the gears and as long as they look the same thy should work.
Old Jul 6, 2006 | 05:21 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
well I read the gears on a distributor of a non-roller cam are not as hard, and if I were to use then on an engine with a roller cam, they'll strip shortly.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
cstrobel65
Aug 15, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
tero
Aug 6, 2015 06:34 PM
