Resitance value of injectors, 14.4 bout right?
Old Jul 6, 2006 | 01:33 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Theres various injector ranging from 30 buck an injector, to 257 bucks per set of 8. I've seen the Venom injectors out there in Jegs catalog for 200, any comments, quick question. Yo check out the lifted Bird.
Attached Thumbnails Resitance value of injectors, 14.4 bout right?-sick-firebird1.jpg
Old Jul 6, 2006 | 05:28 AM
i checked each injectors resistance, they all read 16.5 or 16.4. .....Haynes says resistancE should be 11.0-14.0 Ohms.
Old Jul 6, 2006 | 01:07 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Yea, thats ok. As long as there all the same. Some have slightly higher restance than others. When I had 2 injectors of mine go bad they were reading 2 or 5 ohms while all the others were 14 to 16 ohms. Thoes coil drivers inside the injectors short out and cause either high or super low restance.
Old Jul 6, 2006 | 03:06 PM
thats cool. Thanks....
92-Formula
Dec 12, 2015 10:34 PM
bbsr72
Sep 27, 2015 05:55 AM
89bird2.8
Sep 18, 2015 07:46 PM
webeeZ28
Sep 14, 2015 12:00 PM
Jetmeck
Sep 4, 2015 12:29 AM
