HEI distributor
Old Jul 6, 2006 | 08:07 PM
ricky223's Avatar
Car: 87 Firebird
Engine: 305 4bl
HEI distributor
I have a remote mount coil and i'm wondering if a coil in cap HEI distributor will hook right up to the wiring I have? I'm getting rid of my 305 and getting a 350. The new motor has the coil in cap HEI. I also have a MSD 6a ignition box on the 305 with a harness that plugs into the remote mount coil.
Old Jul 6, 2006 | 08:27 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
The plugs are different, but adapter harnesses are available.
Those distributers are interchangable, if there is nothing wrong with your old one just swap it on to the 350
Old Jul 6, 2006 | 08:42 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
I have the exact same setup. you will have to remove the ignition module and use this.
MSD GM HEI Module Bypass Cable: MSD-8861 - summitracing.com
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
