heater fan wont turn on .i need help
Old May 23, 2006 | 04:17 PM
jamienjason's Avatar
Car: 88 iroc z
Engine: lt1
Transmission: tci turbo 350 street fighter
Axle/Gears: 8.5 10 bolt 3:73 posi
the heater in my 88 iroc recently stopped working,and im not sure what it is.is there any way to find out wether it is the controls in the dash,or the blower motor itself?i turn the switch on the dash and nothing happens.checked all fuses already.please help!!!!!!!!!!!!!!!
Old May 25, 2006 | 08:18 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Check the relay under the hood, near the blower motor.
Old May 25, 2006 | 08:33 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Check for power at the blower motor with the controls on (and make sure the blower wires are all connected). If you have power and the blower motor isn't running, REPLACE IT NOW. A seized blower motor on my '84 started a fire in the engine bay with all the grease and gunk built up in that area.
Old May 31, 2006 | 06:04 PM
Car: 88 iroc z
Engine: lt1
i checked for power at the motor,i think it is a purple wire and a black one that plug into the heater box in the engine bay.neither one of them had power,so is it my heater controls inside the dash that need to be replaced???
i wasnt really sure how to test the relay,so im not sure if thats it either.any info would be helpful.
Last edited by jamienjason; May 31, 2006 at 06:06 PM. Reason: Automerged Doublepost
Old May 31, 2006 | 06:54 PM
bonacci1's Avatar
Car: Lumina Z34
Engine: 3.4 Twin Dual Cams
Transmission: 460TE
Heater fan
Besides the heater not working.
Does your Cooling fan to your radiator still come on?
Do you have A/C? If so does that engage when on?
Last week my son, Tony, his car started to overheat. Come to find out his cooling fan and blower for the inside of the car stopped working. I too checked all the fuses and relays. Read out the cooling fan and the blower motor. Everything was good.
Yesterday evening left it at the dealer to check it out. Today they found the problem. Ready????? It was the ignition switch in the car. Everything is working now.
Hope this helps
Old May 31, 2006 | 07:08 PM
Car: 88 iroc z
Engine: lt1
cooling fan to the radiator still comes on,car doesn't overheat,a/c has been removed from the car.i turn the switches and controls in the dash,and nothing happens.the heater blower won't come on .im beginning to think it is the heater controls in the dash.
Old May 31, 2006 | 07:14 PM
bonacci1's Avatar
Car: Lumina Z34
Transmission: 460TE
Blower motor
The plug on your blower motordoes it have two wire connection going into the blower motor or just one wire connection with the black wire secured in place by the blower motor hardware, grounding it to the motor housing?
Old May 31, 2006 | 07:24 PM
Car: 88 iroc z
Engine: lt1
it has one purple wire that plugs into the blower motor and the black wire just clips on for the ground i guess.
Old May 31, 2006 | 07:27 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Check the relay first with the fan switch on. You should have 12V in and 12V out (not sure on the wire colors or relay location, should be on the firewall). If power in but not out - the relay is toast. If power on both sides, check the resistor on hte blower housing.
Old May 31, 2006 | 07:30 PM
bonacci1's Avatar
Car: Lumina Z34
Transmission: 460TE
Did you try to relocate your grounding wire.
Get a short wire and strip the ends of it. Place one end in the connector end and toch the other end to a ground some where else on the blower motor.
You might just have a bad ground.
I use to have a 76 Nova and when the blower would stop working I found it to be the grounding wire.
Turn on your car with the fan on and wiggle the wire to see if it comes on while you are moving the wire.
Old Jul 7, 2006 | 09:16 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
The relay is fairly new. I changed it when I owned the car. However this also happened to me but I cannot remember what I had to do to fix it sorry.
Oh yea sorry that my buddy bombed your other post.
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
