starter wiring
Old Jul 8, 2006 | 03:19 PM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
starter wiring
i am in the process of installing a slightly modified l98 into a 1989 iroc( i did not remove i bought minus engine). most of the sensors and wiring makes sense but i cannot find all my starter wiring. if somebody could post pics or wiring for the starter that would be great. i am really looking at the negative battery connection and can't figure out where it connects from the battery to the starter. thanks for any help.
Old Jul 9, 2006 | 09:58 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
The negative battery cable does NOT go to the starter. It connects to the engine block (effectively supplying a ground for anything electrical on the engine), mine connects to a bolt by the harmonic balancer. The positive cable is the one that goes to the starter along with some fusible links (which supply everything electrical for the car).
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
