Please help!! t5 harness
Old Jul 10, 2006 | 10:15 PM
92orange's Avatar
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
I want to put a 700r4 in my 88 GTA with busted t5, have automatic chip, trans, convertor, radiator and lines. Need help with the wiring to lockup the converter. What does the two wire plug on the t5's for. I know the rear is for speedo but whats the other for? Can I splice in or change a manual harness to work with a 700r4? Any advice would be greatly appreciated.
Old Jul 10, 2006 | 11:12 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I believe that to be for your back-up lights. My T5 only has the 2 connectors - VSS and back-up lights.
Old Jul 11, 2006 | 08:48 AM
92orange's Avatar
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Anybody have a solution for me?
Old Jul 11, 2006 | 11:40 AM
92orange's Avatar
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Should I try posting this somewhere else? Already tried drive and trans. Surely somebody on here has an answer. Wheres the proffessionals when you need them?
Old Jul 11, 2006 | 12:20 PM
92orange's Avatar
Car: 92 camaro z
Engine: 383
Axle/Gears: 4:11
Thanks!!
Old Jul 13, 2006 | 10:19 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
You could add all the wires for the 700r4 but might be easier to get the harnesses. you will need to have three wires to the trans. one from a fuse through the brake light switch then to the trans. Then two to the ecm. One will be for the high gear switch in the trans and the other for the lockup solenoid. The you will need to run wires from your clutch switch to the shifter for the starter wires. Reroute the reverse lights to the shifter and I think there might be a wire that goes to the computer for park/neutral. Mike
KO1
16
Oct 15, 2015 05:00 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
