fuel problem help
Old Jul 11, 2006 | 10:52 AM
richknapp66's Avatar
fuel problem help, in the electricals ?
90 camaro rs freind bought it as is. I am trying to get it running for him.
ok wired in a push button start bypassing starter cut out, tryed bypassing vat and the but still have a code 52 only have fuel at high rpm (above 3000) have to use outside fuel to start the car and pump the gas pedle to keep it going. the car has nothing above the TB, it all is missing. fuel pressure is good.
any idea's?
Old Jul 11, 2006 | 11:00 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
what do you mean tb has nothing above it.
Old Jul 11, 2006 | 11:17 AM
throdle body, no air cleaner or or anything above the injectores.
Old Jul 11, 2006 | 11:29 AM
Engine: 383 HSR EBL
this is really a proble that should be in the TBI forum there are more experts on TBIs there id try posting there also i reccomend you check your fuel pressure this post will tell you how.
https://www.thirdgen.org/forums/tbi/...-pressure.html
Old Jul 11, 2006 | 11:39 AM
good fuel presure
i beleave it is in the electronics some were.
Old Jul 11, 2006 | 11:45 AM
Engine: 383 HSR EBL
im gonna look up what a code 52 is according to my tpi trouble coded it is a faulty prom but i want to make sure the code is the same for a tbi.
UPDATE: it is either your ecm or your memcal which if im riight is the chip in the computer. i reccomend going to a yard and getting a chip outta car there otherwise its like 80 bucks from gm.
good luck
Old Jul 11, 2006 | 11:57 AM
ok thanks
UPDATE: i will check into that some one told me something about code 52 being with the vat
Old Jul 11, 2006 | 12:26 PM
Engine: 383 HSR EBL
the vats code is code 46
Old Jul 11, 2006 | 12:44 PM
o ok
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
